prv
I'm looking at the circuit diagram in the Yanmar workshop manual (page 12-20). Most of it I understand, but I cannot figure out the purpose of the R terminal.
The basic setup I carried in my head was much like this: http://www.tb-training.co.uk/images/altcct.gif , where the lamp wire provides the initial current to energise the coil. So at first, I thought that R was just a minor enhancement to this, duplicating the lamp circuit with a resistor (mounted inside the regulator casing for practicality) so that the alternator would still work if the lamp blew or was removed.
Then I noticed that BAT is connected to R inside the alternator. This implies two things - firstly that a cable from R is unnecessary, as the R terminal (and hence the coil) will always be energised whenever the battery isolator is connected (which is undesirable anyway), and secondly that the "ignition switch" (engine electric power only, not starting) is being completely bypassed by the cable from switch to BAT to R to the other side of the switch.
Either I'm missing something fundamental or the circuit diagram in Yanmar's own manual is just wrong.
