concentrik
Here's a photo of the exhaust hose run from the water cooled manifold - on a BMW D35 engine. I thought the exhaust was meant to go directly down to the water trap. This does a huge loop up before exiting the engine comptmnt and then going right down to the trap.
It has clearly always been like this as there's only one hole in the bulkhead for the exhaust. The only possibility is that a PO has moved the water trap outside the engine compartment whereas before it was at the bottom of the loop shown.
Are there circumstances when this config is correct? It seems that the water pump needs to build a column of water which is highr than the engine!
