Thepipdoc
I want to cut a rectangular hole in my dashboard to fit a battery monitor. Should I use a fine bladed jigsaw or is there another/better way?
You can get down cutting blades for jigsaws, for cutting laminates, just not from the likes of B&Q
Angle grinder if you have a steady hand...
You can use a Fein Multimaster (or one of the cheaper equivalents) with diamond blade
or a diamond rotary blade in anything from a Dremel type tool to an angle grinder
As has been mentioned you can get carbide tipped blades for cutting GRP but they are expensive and not much good for anything else. I always use fine metal cutting blades at slow speed. GRP is very abrasive so the blade/s won't last that long, but I should imagine for the amount you'll have to cut and where you'll be cutting a couple will be fine.
Just be careful if you need a neat edge that can't be covered because the jigsaw blade is an upward cut and will chip gelcoat if present. Don't forget to wear a mask because the dust is dangerous and also itches like hell.....![]()
It is possible to get downward cutting jigsaw blades made for cutting laminate so less chance of splintering. However, you have to hold the jigsaw firmly down on the work-piece as it doesn't pull itself onto the surface as with upward cutting blades.
I have done this with a Bosch PMF 180 E Multi......
