coco
Having evaluated a whole bunch of Gladiateurs from France to the Netherlands, I settled on a unit based on the french atlantic coast. She looks very clean and well cared for, although a bit meager on the upgrade side and, of course, she is 25 years old already. I had her lifted out of the water before ordering a survey. As far as I could judge with my untrained eyes, this was the best unit I had seen by far.
After allowing for a couple of days ashore to dry, last saturday a survey by a well known surveyor took place. The surveyor had measured the humidity and nothing very bad showed up (Sovereign: between 10 and 24%). No visible osmosis, etc..., but maybe preventive treatment in one or two years.
Before joining the gang in the cockpit, I looked again carefully at the hull outside bottom and noticed a few very slight round bumps and two symetrical (one on each side) square shaped bumps where the shroud attachment plates I suspected were laminated in the hull. Surveyor comes back and looks at the small bumps. Verdict: osmosis.
He then looks at the larger bumps. Astonishment: the hull seems to be delaminated (skin moves inwards).
On Monday we had somebody open one "square bump" and under 2-3 layers of lamination we can see the shroud attachment, that the steel plate is rusty and there is about a 4 mm thick void between the plate and the laminate. It looks like the water in the laminate has corroded the steel and thus delaminated the outer layers of the hull.
Proposed cure: remove the shroud attachment plates competely and relaminate the whole thing using epoxy. This would be done along with the osmosis treatment. Surveyor claims that the boat would be better than new after the repair.
I am little bit concerned: these attachements are probably inducing a lot of stress in the hull skin. And are these the only defects?
Here is my question: would you still buy the boat?
Thanks in advance for any opinion.
PS: might also be a warning for all Gladiateur owners.
