cygnusv
A week ago I installed x4 new Trojan T105 225AH 6 volt batteries in series to give me a 24 volt leisure bank. I also fitted a new Victron blue energy 24 volt 12 amp 4 stage charger (The IP67 one with start interrupt feature). The charger is fitted to the 'common' connection of our 1-2-both-off distribution switch. The cables from the switch to each battery bank is heavy duty and the connections are good.
We use the boat every day and the batteries get regularly, but not too heavily exercised - water pumps and lights etc. At present (and for the rest of the winter) we are connected to shore power.
When I first powered up the new kit, the charger went straight into bulk charge, and exercised itself for about 8 hours before going into 'storage mode' via 'float mode'. Over the last few days the battery voltage has remained at 26.4 volts, as per the spec sheet for storage mode.
Does 26.4 volts seem normal? I must admit that I thought the 'maintained' voltage would be higher.
Edited to add - My main reason for asking this is because we are prone to winter power cuts and will need to run the inverter from time to time.
