What varnish for the inside of a cold-moulded dinghy?
Rosie1963
19 Mar 2014
Ipswich
ramblinginrosie.blogspot.co.uk
Rosie's tender is a Fairley Duckling, and the original varnish used has come to the end of its life. The thing needs stripping and starting again. I am pondering on the varnish options available to me. This is a high traffic/high abrasion area and I am wondering whether a two-pack would be an advantage, or shall I stick to many coats of original?
Whilst I am at it, she is white under the waterline - what paint should I use to re-paint this?
If you can get the inside clean, use clear epoxy followed by two pack polyurethane with a really good UV blocker. To judge by the Nutshell that I built in 1991, you should get twenty years out of this.
If she spends a fair amount of time afloat, white hard racing.
Your Duckling is hot moulded. Do not use a hot air gun to remove old coatings.
Fab dinghies, I love mine. The row perfectly.
Varnish as Kukri says.
Just in case repairs are needed, Fairey Marine released a drawing showing how, copies are available from Fairey Owners Club.
Thanks for the excellent tips. Im finding the scrapping hard as there is no flat surface (slow progress on a very small dia blade) and it seems to me more of a shellac than a varnish.
Ah… the stuff that “Galatea” was thickly coated in… I’m sure it is an ancient varnish formulation. I’m in a position to pass on the benefit of experience.
Don’t use a hot air gun - it will just form a sticky mass and stick more than ever.
Do wait for a cold winter day, use a sharp tungsten carbide scraper and it will come cleanly off in sheets.
Do you still have the Mondeo?
