What type of anti-osmosis barrier layer?
JDH1
New Member
15 Jan 2006
I have nearly finished scraping off 12 layers of antifouling and one coat of poorly cured Gelshield. Unfortunately this has resulted in quite a few scrapes to the gelcoat so I thought it would be prudent to protect the hull with an anti-osmosis barrier layer. I'm trying to weigh up the pros and cons of different products, such as VC Tar 2 and Gelshield 200. Advice to assist in making a decision welcome. Am I correct in understanding the former is more forgiving and simpler to apply? That might be key as I will be applying in the open air. Any other factors to consider
i found the gelshield 200 very easy to work with, cant think of any negative points (except cost and 6 coats)
just stick with the guidelines of temperature etc on the tin
Thanks for the advice. did you apply in the open air? I wonder what learning there was for you from the various applications (I assume you encountered a variety of weather conditions)?
Try and track down a product called ME100. It is also marketed as a 'branded product' in another tin, but I could not find out which, the main advantage is that it is much cheaper than some of the leading makes.
Are you sure that you want to do this? The hull needs to be really deep -down dry to no more than 4% moisture content before epoxying. So called preventive measures can, and do, create the very problem that you are trying to avoid, by creating moisture entrapment and thus accellerating osmosis/hydrolysis.
Sorry if this rains upon your parade.
I would seek professional(i.e. someone who will not from doing the work) advice before applying anything 'anti-osmosis'. I am no expert, but I was not under the impression that scratches to the gel-coat would do anything to increase the progress of osmosis.
i think the important issue here is that you have taken the trouble to remove all the antifoul right back to the gel coat so it would seem a waste not to epoxy the hull (i did it the hard way and know what a back breaker it is)
like the others have said tho make sure you have the hull moisture checked before doing it.
i applied mine outdoors in late march when we had a nice spell last year, i managed to easily get two coats on a day so only took 3 days and it was very easy to put on with a roller.
