andy_wilson
Some years ago I swapped my leaking Volvo shaft seal for a Halyard (I think) seal.
The system works by having a closely machined assembly of metal parts (one rotating one fixed) clamped to the shaft, and a flexible rubber part clamped to the shaft log.
The whole thing is filled with oil, with slight positive pressure supplied by rubber pipes the header tank sited about 300mm above waterline. It is totally maintenance free except for checking the oil level periodically. Despite the following problem, 1 litre (approx) has lasted 5 years!
Problem 1. The pipes (there is a flow and return) to the header have always leaked. The original plastic clips (squeeze together with teeth like a pair of fawceps) leaked so I changed them for jubillee clips which of course aren't totally round, so they leaked too. Strangely the above described plastic clips on the shaft end never leaked. The pipes attach to plastic stubs on the header - it looks like a standard ATF tank that you would find under a car bonnet. The dipstick on the lid is similar too. Any one offer a suggestion of a pipe clamp that will stop the leaking? Failing a better suggestion I was going to use a couple of tie wraps on each.
Secondly, if anyone is still reading, the litereature is on the boat 320 miles away. I think this system uses AFT, but can anyone who knows the system confirm this?
TA
Andy
TA
Andy
