happyboater69
I have got a whole lot of unused Volvo parts that I am struggling to off load.
There are so many that Ebay isn't an option particularly given the weight of some of the items!!
Too many to list in the for sale section on this site again because of the number involved.
Bearing in mind these are all still wrapped and all new how should I sell them on?
The list of bits is below, the whole lot works out at over £2500 and I don't want anything like that for them.....
The stuff:
1 Control lever assembly PC-840, top 853168 75.35 75.35
1  Hot Water Outlet 3841173 38.53 38.53
1  SERVICE KIT 3818189 141.65 141.65
1  BULB 863946 4.39 4.39
1  IMPELLER KIT 3841697 39.94 39.94
1  V-BELT 973487 23.74 23.74
1  DRIVE BELT 861564 40.31 40.31
1  DRIVE BELT 3581460 44.84 44.84
1  Serpentine Belt w/ Manual Steering 3860092
1  V-BELT 977542 18.46 18.46
1  O-RING 925027 5.83 5.83
7  O-RING 947663 19.14 133.98
1  O-RING 968927 3.76 3.76
1  O-RING 955976 2.48 2.48
1  GASKET 819959 3.20 3.20
1  GASKET 833994 1.01 1.01
1  SEALING RING 3829315 53.71 53.71
10  O-RING 944988 3.16 31.60
1  GASKET 859015 10.83 10.83
1  O-RING 949659 3.11 3.11
1  SEALING RING 831892 4.72 4.72
1  GASKET 1378491 4.90 4.90
1  GASKET 1275549 6.51 6.51
1  GASKET 3514546 2.80 2.80
1  DAMPER KIT 840634 13.10 13.10
1  Connector 1/4" 3825000 4.19 4.19
4  NUT 971071 0.69 2.76
2  SWITCH 976256 2.10 4.20
2  CLEVIS PIN 872126 8.22 16.44
1  Coil 35254 50.95 50.95
3  Spark Plugs 876077 42.28 126.84
2  Spark Plugs 875820 26.97 53.94
1  Spark Plugs 3858997 57.93 57.93
1  REPAIR KIT 875756 130.83 130.83
1  TEMPERATURE SENSOR 862567 86.13 86.13
1  THERMOSTAT KIT 877355 29.66 29.66
1  Thermostat 875580 31.28 31.28
1  THERMOSTAT KIT 876080 53.87 53.87
2  THERMOSTAT KIT 3831424 32.66 65.32
1  THERMOSTAT KIT 875783 66.61 66.61
1  THERMOSTAT 861911 15.96 15.96
1  CONTROL PANEL 3855650 85.87 85.87
1  REV COUNTER KIT 858557 212.77 212.77
1  PUSH BUTTON 876950 82.74 82.74
1  THERMOSTAT 3839110 45.80 45.80
1  Filter Kit 3855104 10.53 10.53
1  ZINC RING KIT 875805 10.37 10.37
1  Rudder Indicator 863944 81.38 81.38
2  HOSE CONNECTION 840509 24.06 48.12
1  TAP 807036 18.37 18.37
1  Block Drain 1/8 966871 35.03 35.03
1  PRESSURE MONITOR 873597 34.89 34.89
2  DRAIN COCK 829592 17.99 35.98
2  Fuse Box 873566 45.63 91.26
1  Rotor 243657 17.22 17.22
1  NUT 955806 2.57 2.57
2  BANJO NIPPLE 3583445 8.36 16.72
1  Rotor 243903 9.93 9.93
2  SWITCH 828584 24.76 49.52
1  RELAY 854357
2  Oil Filter 835779 9.98 19.96
7  Fuel Filter 3862228 10.53 73.71
1  FUEL FILTER KIT 3817517 80.99 80.99
1  CIRCULATION PUMP 3812236 826.54 826.54
1  PRESSURE CAP 1674083 21.04 21.04
1  ZINC ANODE KIT 876638 22.62 22.62
9  ZINC ANODE KIT 852018 25.93 233.37
1  HYDRAULIC HOSE 3863405 54.62 54.62
1  HYDRAULIC HOSE 3853857 45.92
1  Stop Cable - 6.9M 825764 37.28 37.28
1  ZINC RING KIT 875810 28.40 28.40
3  ZINC RING KIT 875812 34.29 102.87
1  ANODE KIT 3588745 24.17 24.17
2  NEUTRALIZING AGENT - Quart 41103103
1  Engine Paint 827501 11.67 11.67
1  Engine Touch-up Paint Spray Can 1141566
1 3812269 STEERING CYLINDER
Plus more that I don't have time to list!
Any ideas guys??
The stuff:
Any ideas guys??
