What pressure for HW expansion vessel with 2.9 Par Max pump?
Modulation
30 May 2001
finder
Just replacing my HW calorifier and decided to fit an expansion tank to take up the volume expansion as the water heats up. I'm not sure what pressure I should set the vessel to, though - can't find clear guidance anywhere and the fitting instructions are long gone. The pump is a Par max 2.9 and its maximum pressure rating is 1.7 bar (25psi).
So should I set it at just above or just below that?
Thanks all
Thanks all
I think you will find all the necessary info here https://www.jabscoshop.com/files/Accumulator and Expansion Tank Instructions ZPWL4 doc595.pdf to enable you to select the right size of tank and set the pressure
