Is this project boat wooden or fibreglass?
No, it's moisture that has collected between the fibreglass and the paint.Thats funny because I've just been doing some research and I think it's also paint.
So... its just cracked paint right?
This could be due to damp within the fibreglass (most likely) or it could be from when sprayed (bodge job). If the fibreglass was not dry or the spray equipement did not have a good water trap or was sprayed in too humid conditions then the moisture could have been there from then.
Either way the paint will need to come off and fibreglass thoroughly dried before any further finish is applied.
Difficult to answer. Provided the boat is kept in a warm dry workshop or similar and the air can circulate freely both outside and inside hull then probably a month would do. If it's not kept in warm dry area then it's unlikely it will ever dry out.... how long do you suggest for it to dry?
hello,
I found this on a boat I'm looking at as a project?
It's forming around the bow...
What is it? Repairs for it?
If it will never dry out then is their a solution...
Bit doom and gloom.
It's only a £40 boat so I'm not going to be looking for a perfect quality finish just want some fun and got the winter to get it ready. How long will it take for it to re-occur if I sand it down fill any holes prime and re-paint.
For the drying out, how long is a piece of string? Not much help but if under cover and some air movers it might be a few weeks if lucky.
Two to three months in the open wii reduce the moisture content dramatically!
Agreed - it takes 10-20 years or sometimes longer for water molecules to get into sound, dry GRP: it does not dry out fast.of wood, yes. Not of GRP.
