What is the name of this anchor
LaurenceK
25 Nov 2004
Been sailing for quite a long time now and I'm surprised to discover that I don't know the name of a particular anchor. In itself this is not a problem but I now have to buy one and this yawning abyss in my knowledge is causing me some grief.
The anchor has a short, stout stock hinged at the base to a crosspiece which lies at right angles. At the end of each side there is a large fluke pointing vertically up. This is the type of anchor most frequently seen on ships rather than boats and appears to be more about bulk and weight than ability to dig itself in.
Sorry if that is a bit of a weak description but 'tis the best I can do.
LaurenceK
25 Nov 2004
Thats close but whereas these flukes are curved the one I am looking for has straight flukes with their axis parallel to the stock.
Thanks for yours (and others) help.
Marsupial
5 Jul 2004
I think Maxi is nearer the mark, they are also called dreadnaught anchors - for obvious reasons. But without seeing it who knows?
Evadne
27 Feb 2003
Hampshire, UK
Admiralty pattern is often another name for the Fisherman's (anchor-shaped) anchor. The <A target="_blank" HREF=http://www.higwoodanchors.com.au/dreadnoughtanchor.htm> Dreadnought </A> looks very similar to the Hall, with less curved, angled arms.
LaurenceK
25 Nov 2004
The Dreadnought is certainly closer than the Hall (see posting above) but arms still curved.
I seem to be learning a lot .......
LaurenceK
25 Nov 2004
I have bought a big barge and I need a big anchor that can sit on the bow and be deployed without having to try and manhandle it over the side. That style of anchor is the only one that will fit in the space
Evadne
27 Feb 2003
Hampshire, UK
Beat me to it. All the other names are <A target="_blank" HREF=http://www.nvo.com/baldtus/po003data/> here </A>, if you want to go the whole anorak! It could even be the "snug stowing stockless". I got distracted reading it.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Sounds like a <A target="_blank" HREF=http://www.marinestore.co.uk/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=grapnel-anchors> Folding Grapnel </A> to me.
<P ID="edit"><FONT SIZE=-1>Edited by NigelB on 25/11/2004 18:35 (server time).</FONT></P>
hylas
6 Nov 2002
Canaries Islands
This anchor is very common here in Brazil. You will find it under the name of 'Pekny' in the "Bible" "the great book on anchoring and mooring" from Earl Hinz
