What is the best light weight tender with big tubes and air deck
I have the same problem and have been looking for a year. Neither Zodiac or Honwave meet the lightweight criteria. The problem is the lightweight ones tend appear flimsey. They all suffer from UV and the glue is reported to fail on some fittings. I need one to fit in the locker too. You get 37cm tubes on a 2.5m Seago go lite, with an inflatable floor. It packs small as well. but then it is black which is no good for the sun. Seems you can't win.
A friend has the 3d SUPERLIGHT TWIN VIB AIR 280. It has large tubes and a V'd air floor, at 25Kg Its much lighter than my 40kg Excel 290 of similar configuration, OK its not as robust but getting it on and off the boat is a lot easier and its as seaworthy IMHO.
The flat very light air floor 3d tenders of the Twin air range are not in my opinion nearly as seaworthy, with smaller tubes and no V in the floor. Do not confuse them!
Not the Excel Ventura series in my experience. The towing eyes tore after a couple of years. I had them replaced with Zodiac ones and they're doing the job. My 230 is quite difficult to row as my knees get in the way of the return stroke. but I suspect that's a "feature" of most smaller flubbers.
Mmm, they should do an AX2.5. The 2 serves well for what I wanted, the AX3 would have been better for an extra guest or choppier water but was just too big and heavy to stow on the current boat.
LodeStar Ultra Light inflatables
I bought a Lodestar 250 about 9 years ago and it's been excellent. Still looks like new despite lots of use., inflation, deflation, rolling up and storing etc... it's well built and with everything you would normally expect in a decent dingy. Note: it's not super light incidentally so check the weight spec. They lose some of the weight by removing some fittings like the rubbing strip on the tubes. I thought at first that might be an issue but it hasn't. I have been very happy with the Lodestar. If I recall correctly it was a fair bit more expensive than most similar sized tenders at the time. Sounds exactly what you are after.
I am now on my second Quicksilver Airdeck. The first, a 2.8, lasted 12 years with me and 2 with the guy I passed it on to. Almost all of those years in Med sun. My current one is a 2.3, fits the foredeck better but is not as pleasant to use as the 2.8 was.
Between those two I had a SunSport 2.3 ARIB. Only kept it two seasons, not a success for us.
Any ideas on a UK stockist for Lodestar gents. Google hasn't really turned up any options.
The Quicksilver 280 looks good too but they only make 250 or 300 now it seems.
They are based in Holland if you google lonestar dealers you will get them.
