Skylark
I have a small tear around the luff / bolt rope near the head of my mainsail. The area gets a fair amount of flex, simply raising and lowering the sail as the luff flakes down the mast track.
I've wrapped the luff using 4 inch wide self adhesive sail repair tape. After only a week or so the tape is starting to lift. The tape length is about 6 inch on one side and about 4 inches the other, as it wraps around the luff.
A couple of questions. Perhaps the sail was not clean enough for the adhesive. What should I use to clean the area thoughly?
Should I "belt and braces" by adding additional adhesive to the repair tape, if so, what type?
Any help and advice appreciated, thanks.
