Caer Urfa
My stantion posts have 4 holes for fastening them to the deck, the 'outside pair' are though bolted through the top wood and grp and bolted inside the hull, the 'inside pair' of holes are only screwed into the wood top and due to wear now do not tighten.
The inside ones 'can not be through bolted' due to internal access.
Is there a good wood glue or resin I can get and pour or pump it into the wood holes and then re-screw the screws into it so it will set hard and solid again?
All screws 6mm dia.
All advise appreciated
All screws 6mm dia.
