Mike k
Sorry if this is a daft question but the instruction on a R and D rope cutter require a 3mm dimple to be drilled on the shaft to take the grub screw to hold the cutter on the shaft. R and D supply everything to do the job but as the bit will create a proper dimple i.e deeper in the middle and shallower at the sides - does anyone know where the 3mm should be i.e in the middle of the hollow or at the edges of the dimple( meaning a deeper than 3mm cut). I have put a call into to R and D but its weekend and I would like to do it on Monday so any views would be welcome. Many thanks in advance
Mike
Mike
