What do people think of this project.
harvey38
27 May 2008
I'd check the integrity of the forward deck/galley roof, looks like a lot of heat marking there, I'd be then checking cabling in the same area and behind the instrument console but it still a lot of money for an unknown quantity.
James jameson
17 Jul 2022
Brave to take that on. The heat can take the resin or strength out of it at least may look ok but also could be very weak.
If you’re up to making mouldings. Sections of grp etc
But without seeing and a proper check could be a massive can of expensive worms.
Stingo
17 Oct 2001
Getting drunk with your daughter
Hi
winter has me itching for a project.
was wondering what peoples opinions are on this sealine s38 project.
2004 Sealine S38 | BOAT SALVAGE
anybody have any experience with refitting interior trims (are trims still available anywhere or are sealing parts not available anywhere,
thanks
The seller/boatyard should pay you good money to take it off their hands.
Alex_Blackwood
19 May 2003
Fareham
Hi
thanks
Buy it, strip it down and sell it for spares. Then pay someone to take away the remains 🤣
Bouba
6 Sep 2016
SoF
Did it burn and sink ?
I wouldn’t touch it with out knowing how hot that fire got.
If I did…I would strip it very very carefully…photographing everything to see how it went back together. I would not throw a thing away…I would store it carefully labelled or in the same position that it came out in…what can’t be salvaged will be your template.
Personally I would walk away…sad, because from the outside it looks a lovely boat
Freebee
21 Oct 2001
Alton, hants
you would be buying sold as seen so you have all the risk.....apart from structural damage there is soft furnishing and cabinetry replacement and a legion of unknowns ....if you have good diy skills you may manage a reasonable result but if you are employing others the bills will soon escalate.... the value at present is in the secondhand engines and drives and other sellable bits and bobs strikes me at 47k its too much money!! and the smell ugh and toxic too.
russ
9 Nov 2009
North East Hampshire
The reason for not leaving an unattended dehumidifier running.
For another £50-60k you can buy a turn-key boat without all the grief.
Some S38 parts are still available but at huge cost. They also use the Seaplex wiring system which is now toast.
Check the structural repairs were carried out by either Sealine or Desty and theres a certificate.
jakew009
29 May 2012
It's advertised for way too much money; if it was pristine it's worth what 90-100k if you can find a buyer, so you have 45-50k you could spend on it.
But even when it's fixed up it's still going to sell at a heavy discount unless you can reinvent it and disguise it's history.
50k would disappear in days in just parts to refit it.
Realistically even if they paid you 20k to take it away it would still end up a bad deal if you repaired it. It needs to be stripped out for parts and as someone else said, it's currently worth the market value of the engines (say 8k each).
