Grt
New Member
The stbd Kad32 on my s28 has always breathed quite heavily leaving a trail of oil under the engine and into the bilge. It usually occurs after a run of a couple of hours.
I’ve just had it serviced including new oil and crank case filter but from the short distance from my berth to the hard it has already spit out oil. The dipstick measures at least a cm above the max mark. Could too much oil cause damage or excess breathing? (I am sure it is from the breather and not a spillage!)
