What 30 footer?
You'd consider a boat that you know hasn't been built properly!!!! /forums/images/graemlins/confused.gif
However, check whether the inner shouds mountings have been beefed up - the original had a fairly inadequate metal plate embedded in the deck lay-up. If there is any sign of cracking round this, an upgrade is needed.
Then you have to hope its a beef up not a bodge up!
Is there any boat there has never been a problem with?!!
Your next one? /forums/images/graemlins/wink.gif
If you are happy going off shore with a boat with such a major build issue, and the one described is, then its your choice. Its not that there aren't any others to chose from.
Depends if you can confirm that the design error has been fixed ... probably better if it hasn't been and then you can get it fixed yourself... then you'll know that it is done properly ...
