fergycool
I've replaced my old bilge pumps with the two Whale Supersub smart pumps. Both sizes.
Both are fitted with NRV and recommended hose sizes.
The only criticism is that both pumps will not start moving water until water depth is higher than the strum boxes. This is way deeper than the 9mm thy say they will remove the water to. The pump appears to just spin. It just does not seem to be self priming until it is sucking from a lot of water.
I can cheat this by putting my finger over the "bleed ball" vent on top of the strum box.
Once the water starts to be "sucked" it will be drained to the stated depth.
Is this normal?
Ironically this means to "empty" my bilges I must first add a bucket or two to raise the level
Cheers
Chris
Is this normal?
Cheers
Chris
