Whale BE9003 'Field Sensor' bilge switch
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
Does anyone have any feedback (good or bad) on the Whale BE9003 'Field Sensor' bilge switch? (same function as a float-switch).
I have read the thread from around 9/2013 but it doesn't really say anything specific.
I am specifically wondering about long term reliability and whether oily bilge water causes any problems. I do note that it consumes a constant 8mA (which equates to around 6Ah/month).
And yes ... I know that 'ALL' float switches are notoriously unreliable. (personally I have found the roller-ball type the best of the bad bunch).
I reckon 6AH per month is a lot cheaper then the problem the last (leaking) switch caused to my anodes and prop tips !
Fitted one about a year ago and no problems so far, but having said that it has not had to operate apart from when I have washed through the bilge when it worked impeccably. If I need to replace the other float switches on OB I shall fit these.
