RichardS
N/A
The "Shakedown" thread on Scuttlebutt explains about my exhaust hose suddenly spraying water everywhere over the engine.
The hose fitted at the moment is made by Megaflex and the one thing it is not is flexible. I have thought about binding it with self-annealing tape, at least as a temporary measure, but I can foresee that the main problem is going to be getting the 2m length out of the engine compartment which I will need to do to tape it. I realise that taping the hose is not ideal but my engine compartments are separate and well aft any cabins so it's not too bodgy, although it would be good to get the job done and finished and hopefully with something that lasts a bit longer as the Megaflex hose is stamped Q4 2007 which seems a poor show.
I've just looked at the51mm Seaflow hose sold by ASAP and that says that it is very flexible so should be a lot easier to get back in than this MegaNonFlex stuff, assuming that the Seaflow is actually any better.
I changed all my toilet hose from stiff PVC stuff to lovely rubbery stuff bought from ASAP a couple of years ago and I would like to pull the same trick again with the exhaust hose, at least on the port engine.
Can anyone advise me whether the Seaflow stuff will deliver on its promise or is there anything better?
Thanks.
Richard
Thanks.
Richard
