Jonebarl
I have two problems. One annoying and not yet expensive, the other worrying and probably expensive (I'm in Norway, so anything that needs professional fixing is £80 per hour labour!!).
1) The inner partitions (if that's what they are called) seem to be coming away from the hull. Looks like they've been repaired with fibergalss previously to no avail. How could I make a permanent repair - assuming that simply sanding, adding fiberglass mat then painting will not last. Is this a design flaw or weakness as the outer hull flexes and the inner doesn't?
Here's photo :View attachment 13353
2) I've got leaks. I suspect the root cause maybe something like my first problem, it could be the fender rubber, it could be where the walkaround teak deck is screwed through the fiberglass, or it could be the windscreen. Ayy hints if theres someone out there with a similar boat (it's VERY similar to an Aquador).
Helpful hints appreciated.View attachment 13354
