aussimed
New Member
I have recently purchased a westerly sealord with a Buhk DV36 hp engine and a two bladed propeller.
I am still getting to know the boat and how to sail it properly, particularly with an in-mast furling mainsail since I am used to traditional slab reefing mainsails. The boat does not seem to sail well to windward in strong winds, as she does not point high into the wind, is this due to the furling mainsail without any battens and also could it be due to the roller genoa which does not have the right cut to sail, when it is reefed in?
At around 2000 to 2400 r.p.m. cruising speed is 5.5 to 6 or 6.5 knots depending on sea state and wind conditions. I would like to know what type of fixed three bladed propeller suits this type of sailing yacht, so as to increase the cruising speed while mantaining the same engine revs and with the same fuel consumption.
Does Anybody have any experience with changing a propeller from 2 bladed to 3 bladed? On a cruising yacht I assume drag would be minimal. But does changing the propeller require alterations to the shaft or gearbox? Is it true that a shaft lock would have to be fitted to prevent shaft from turning during sailing?
I Thank you for your feedback in advance.
