mickywillis
Have posted this question on the WOA forum as well, so thought I'd try members here!!
Does anyone know what the lower bearing carrier on a Pageant (and indeed the Centaur) bolts into?
On Zara, one of the 4 bolts that go up into the hull is loose, but doesn't pull out, suggesting that the nut or backing plate which it is attached to is still fitted and possibly seized?
Tese 4 bolts are the ones seen when looking up at the stern of the boat, just above the top of the upper edge of the rudder. they must hold the lower bearing carrier into the hull? i amd assuming that the bolts fit into captive nuts, bonded in with the GRP, but I cannot see them either in the cockpit locker or in the cockpit itself, under the tiller handle, where the shaft exits. I guess the only way to get to them is by removing the fuel tank and crawling into the void between the aft end of the cockpit access hatch and the stern locker??
Picture can be viewed at:
http://i705.photobucket.com/albums/ww56 ... C01335.jpg
Thanks,
Thanks,
