winship
Active Member
The Wema fuel level sender fitted in my Pedro is defunct and no longer produced by WEMA. USA It is a self contained plastic tube fitted into a vertical steel tube welded to the side of the fuel tank. At the top of the unit there is a plastic spigot with a flexible plastc pipe which goes into the fuel tank. Presume it is required to prevent an air lock in the sender unit. Wema suggests their S3U unit as a replacement. How would I prevent an air lock? The S3U does not appear to have provision for the flexible plastic pipe. It would be quite a problem to drill and tap into the vertical steel tube I have only seen a photograph of the S3U and WEMA seem to be filing my e.mails at the bottom of the 'Too difficult Tray. Any help or information would be very much appreciated. James
