pmorris
I've just took the head off a mini petter single, in the first process of a rebuild as there was not enough compression to get it to start easily. (When it was running it sounded quite smooth.) One of the water ports has corroded nearly to the edge of the cylinder, but apart from that evervything else seems as new. There is no other corrosion, no movement in piston and the bore looks fine.
Is it possible to have the head welded and reground, and if so, are there any drawbacks with this.
The boat has been standing for over a year, but previous to this I think was a good starter.
Could this be the cause of the bad starting.
Would it be feasible to just have the head done and refit it, as to overhaul the whole engine I'm told will cost between £300 and £500.
I didn,t want to spend this kind of money when in probably a couple of years time I might change it for a larger engine, as it is supposed to under powered for the boat a Seal 26
