Weed infested line
kalanka
21 Jan 2005
North West Scotland
I have about 100m of old braided line about 12mm diameter that is used as the push-pull line on a running mooring for a hard dinghy in a sheltered bay.. Most winters I lift and dry out the rope but last winter was unable to do this.
Predictably a large colony of weed has taken root in the line. This winter it is ashore and I have loose coiled it over a fence in the hope that the hard winter frosts in N Scotland will get rid of the week for next season.
Any better ideas?
STOL71
17 Sep 2014
London
www.shuda-sailing.com
Any better ideas?
Pressure washer
langstonelayabout
1 Jul 2012
Portsmouth, UK
Washing machine.
Soak it in a bucket of warm water and napisan for a while and then straight into your washing machine for a full wash at 40 degrees.
What you get out will be a whole lot better, if not perfect.
Beware: if you rope is old the washing machine may destroy it faster than the sea. Also, my wife hates me using the washing machine for ropes...
sarabande
6 May 2005
Dump it in a bin of water just covering the rope. Add a cup of Patio Magic. Leave for a week. Agitate and agitate for ages with a hosepipe running into the bin till the water runs clear, The weed and roots die and metamorphose into muddy sludge.
Soak it in strong PM before you re-lay it and the weed will take ages to re-colonise.
johnalison
14 Feb 2007
Essex
That won't please those who are concerned about the effect of PM on marine life, though quite how bad this would be I have no idea.
penberth3
9 Jun 2017
I've seen something for cleaning muddy caving ropes. Basically a tube lined with something like astroturf - green side inwards! Easy to improvise something like that - two scrubbing brushes cable tied together or whatever.
Or simply set up a plank at a convenient working height and scrub by hand, 3m at a time, won't take too long.
BTW, I don't like the idea of using unknown chemicals on rope.
alan_d
15 Mar 2002
Scotland
I have a similar problem with the pick-up rope on my mooring, it is very hirsute by the Spring. At the start of the season I run the back of a knife-blade along it to get rid of much of the hairy stuff and find that once the boat is on the mooring and the pick-up rope is out of the water a combination of drying out and rainwater soaking soon sorts it out. I would guess that if you have scraped off the worst of the growth the fence treatment should do the trick.
