Webasto thermo top v help!
trebby67
14 Apr 2009
Hi, All.
Just bought a brand new Webasto thermo top v (main unit only)
I want to fit it into my boat It was old stock and there are no instructions with it.
Just need to know what I need to do to fire it up.
There are 2 conectors 1 X 8 pin numbered 1-8 and 1 X 2pin 1-2.
Can anyone help?
A simple diagram would help.
Regards Brian
trebby67
14 Apr 2009
Hi, thanks but it does not say anything about the wiring.
Also you need dealer a password and login to get further into the site.
Regards Brian
Ceejay
28 Jul 2002
First posting, and you have a brand new Webasto and no installation instructions?
Sounds like it may be stolen property to me. Something's not quite right.
CJ
trebby67
14 Apr 2009
Hi, Ceejay.
What a sad world it would be if everyone thought like you!
See item number: 350185010600 on Ebay.
Regards Brian
DavidMcMullan
19 Jun 2003
Bangor, N.Ireland
Brian,
I have a copy of the installation instructions for a Thermotop C, which has a wiring diagram. I could copy this for you, if you think it would be useful. PM me with your e-mail address.
David.
Ceejay
28 Jul 2002
Hi Brian
I only said it may be stolen. I did hear somewhere that there are one or two crooks on e-bay, hopefully not your seller.
Regards
CJ
epiccontrol
19 Apr 2009
The controller in the thermo top V is specifically programmed to work only with the vehicles computer that it came out of. The wiring diagram wouldn't help you because you need a digital signal. I ran into the same problem and I made a prototype controller. It works well. It will require some custom wiring, but it's not too complicated.
gavbriggs
6 Jan 2010
hi, i'm retro fitting the thermotop c to a range rover p38, i know its not boat related but it may be of use to boat owners, after fitting the unit it will go through it's start sequence, but as it goes into full burn it the fails to detect the flame, any idea what this could be?
i am told the resistance on the glow pin/flame detector 'should' be .6 ohm at room temp, is this correct, can anyone check and verify?
i have two units, one with dead pcb, both glow pins show the same resistance at the same temp
thanks
Gav
thor
22 Apr 2014
Is it possible that you can share detailed info about this, a wiring diagram and how to built this controller? Please!
