blampied
Hi
Looking for someone who has experience with installing Thermo Tops into a boat.
I am installing a Webasto thermo top c into a 33 foot boat
Looking for advice on how to plumb the thermo top C hot water to the domestic hot water tank,
(the instructions from Webasto are almost none existent)
I have the hot water from the webasto boiler fed through the radiators then through one side of the heat exchanger which I have installed alongside the boats domestic hot water cylinder
it's how to plumb the other side of the heat exchanger into the hot water tank that's causing confusion.
There are 4connections on the domestic hot water tank,
2 plastic pipes for cold water in and hot water out (drinking, washing water)
I'm assuming it is not this drinking water that needs to feed through the heat exchanger?
& 2 rubber pipe feeds from the engine cooling water (water in the pipes is green with anti freeze)
I'm assuming its one of these rubber tubes that I need to route through the heat exchanger?
A lower one (coloured blue) that has a feed from the engine
A upper one (coloured red) that has a feed from the engine
One will be in and one will be out, but which one is which?
Which one do I need to disconnect to route through the webasto heat exchanger
Regards
Paul
Regards
Paul
