Webasto exhaust silencer - help please
[2574]
29 Nov 2002
I was going to fit a silencer to our warm air diesel fired heater at the weekend. Out of idle interest (and self preservation) I blocked one end (outlet) of the silencer with my thumb and blew in the other end (the idea being a pressure test to make sure there was no leaks). I was mighty surprised when there was clear passage of air to a third outlet. There is a hole (in the join of the two part body) of about 2mm diameter where air is free to pass. The hole appears to be entirely intentional - this is a brand new unit and is undamaged; the aforementioned hole appears to have been designed in to the unit.
So; why does the hole exist? In my simple mind this hole will allow noxious gas to escape from the exhaust system in to the boat. I abandoned fitting the unit until I had sought guidance from others more wise than I - can anyone shed any light?
Thanks in advance
Rob
Looking at the manual, I think a coil is supposed to be attached and filled with water.See page 11 of manual (download from site).
Just fitted mine at the weekend....just left with a red fuse and about 2 foot of maybe 25 mm dia pipe? Any ideas?
See reply to your other post re fuse. The pipe is probably the inlet combustion air pipe---so you can take the air from a distance from the unit itself.
