Webasto Airtop 2000 st problems
Sam j
New Member
19 Apr 2023
Hi All,
I have a puzzling issue with my AT2000 st.
The crux of the problem is that the fuel pump will not run and throws the 1 flash failure to start code.
If I tap 12v to the pump directly it will work.
If I connect the switching contacts of a relay to the fuel pump wiring, the relay clicks.
If I connect a 12v battery to the switched contacts of the relay and then to the pump it runs and the heater works.
I have replaced the pump ecu with a second hand unit - still not working.
I have replaced the rest of the heater with a second hand unit - still not working.
I have wired the heater directly to a battery with fresh cables - still not working
I am very much out of ideas at this point. The only items that I have not changed are the rheostat, the pump and the wiring loom.
Has anyone else had a similar experience or can offer some direction?
Best regards
Sam
Yes that has crossed my mind. I found a cheap secondhand until that I have used for the spares mentioned above but I would need to buy a controller and pump to complete the set which will cost ££
It turns out it was the fuel pump. Even though I could pulse it manually with a 12v battery the heater could not run it. It had 0.7ohms across the pump terminals, this should be around 5 apparently.
I hope this thread will help someone in the future
  • Like
Reactions: FWB
