Waxing issues!!!
Stretch
25 Aug 2003
usa, gulf coast
hello to all..i wanted to post on here and see if anyone has any advice on this......
i have been doing a lot of waxing on a boat i work on. when waxing large areas i seem to be getting the swirled/blotchy look. i have been using mainly 3m and collinite paste wax. i have experimented with liquid wax and notice that it is much easier to work with, but would like to get a good paste wax base coat for the long term. i am waxing gel coat that is in good shape overall. i am cleaning it with soap/water...then pre wax cleaner prior to waxing. any advice to getting a good, even look?? am i maybe using to much wax?? not keeping the buffer pad clean enough?? what gives?? thanks in advance!
If you are using a rotating pad then that is your problem.
At Port Hamble one year a contractor persuaded several owners to have their hulls "Professionally" waxed. The guy used a rotating pad on a geared down angle grinder. In the daylight the hulls looked pristine but in the dimming light of dusk and then the sodium lights of the car/boat park all the swirls and patches showed.
What you need if you MUSt use mechanical means is a "Random Orbital Polisher" as used in car showrooms. These can be hired or even bought for not much cash from places like Autostores and Makro - who sell(at times) a 12 volt version.
Personally, I always use elbowgrease - it takes a lot of time and effort but spread over several weekends of the winter which season is best anyway to avoid streaks & blotches.
Since it is the barrier coat remaining after buffing that provides the protection, I doubt that the original consistency of the wax or it's application medium have any bearing on it's durability.
Steve Cronin
Stretch
25 Aug 2003
usa, gulf coast
hey thanks steve! that may just be the tip that i needed. i have been working on boats for quite a few years and have been on almost all metal boats. dealing with large areas off gel coat is new to me. i have 84' to deal with so i for sure think mechanical means is the way to go. thanks for the advice. i will try a random orbital polisher and go from there!!
david_e
1 Oct 2001
www.touraine.blogspot.com
If the gel coat is in good condition the a polish with teflon should be OK.
At the start of the season I used the starbrite with teflon polish, twice within a month as recommended, and after 30 separate journeys am still getting a good beading of water when I wash off on all but the fine bow entry which needs to slightly re-done.
Very easy to put on and polish off by hand.
As an alternative, if doing professionally for re-finishing, you might also consider Autoglym restoration polish (foregt the model number). Some of the mobo chaps swear by it, it has a very, very fine abrasive rub within the polish. Good for use by hand or polisher.
Stretch
25 Aug 2003
usa, gulf coast
the gel coat is in really good shape overall. the are/were some spots that were dry with almost none to very little oxidation. nothing in need of any more than a very light compounding.
i would love to use teflon polish but have been scared of it. i could care less about the "more trouble to paint later" argument, but the "yellowing" argument scares me. is there any truth to that, or is it perhaps a problem from years ago that has been corrected in the recent years?? also, is it good to get a good wax base coat down before you use the teflon polish?? there is a white 112' down the dock that uses teflon wax with good results. i have been waiting for it to yellow but it hasn't happened yet!!haha
ArthurWood
21 Jun 2001
SW Florida
Hi Steve - have read quite the opposite, ie that orbital polishers cause swirls. Non of the professional boat polishing people around here use random thingies, rather the large- headed sander-type with about 10" dia fluffy buffer.
