JollyRodgers
Waterpump: Flojet R2100 (discontinued)
Accumulator Tank: Jabsco 1Litre
Hello again,
I think I spoke to soon when I told my Dad that I was happy to have almost finished all the jobs on my boat .. haha
I went to do the washing up last night, switched the water pump on and it made it's usual groaning sound. Normally it does this for a few second and turns off and if I leave the tap on it will keep doing it every 10 seconds or so. This time it just stayed on for around 30 seconds but no water was coming out. I looked at the water tanks and they were quite low, so I figured that perhaps there wasn't enough water in there to build up the pressure.
I topped up the water to full and tried it again, but had the same issue. Loud groaning sound for 30seconds + until i turned it off and no water.
I screwed the lid of the wooden box that the water pump was attached to and from what I can make out it works as follows;
1) There is a pipe that connects the flexible water tanks and the water pump together, which runs under the floorboards. The pump sucks in the water through this.
2) The pump does his thing and then spits the water out with pressure out of the other pump, which then goes through the accumulator and into which ever tap is open.
From what I can see, the water is no longer being sucked up in from the first pipe. Would that indicate that the water pump was busted and needed replacing? Or would it indicate that there is a loose seal or a split pipe, which is making the pump useless because it's just breathing in air?
As you can see from the photographs, the pump is pretty ancient. No idea how old it is, but judging from Google it has been discontinued some time ago.
Not entirely sure what the accumulator does either, but I dont think there is a fault with that, because water isnt even reaching the pump and the accumulator is on the other side of that.
Does anyone know roughly what would be causing this, or had a similar problem?
Thanks.
PS: if it helps, I think that there maybe a slight leak from connecting pipe because there is usually a little bit of fresh water under the floor boards. Originally I thought that this was rain water, but after redoing the seals in the cockpit and no rain getting into the engine bay I dont think this is the case. I also didnt realise at first that the water tank has a pipe that runs through the floorboards to the water pump (sounds obvious now, but I never thought about it). Something that I need to fix whatever the issue with the water pump..
Hello again,
Thanks.
