Waterproof grease
Avocet
3 Jun 2001
Cumbria
I've exhausted my supply of Duckhams Keenol for the stern tube, and it doesn't seem to be available any more. Could I ask for recommendations, please? I see there's some quite expensive stuff called Ramonol now, plus a variety of other cheaper greases that claim to be "waterproof" or "marine". Is Ramonol worth the extra? (Boat is in freshwater, rather than seawater, if that makes a difference)?
On the principle that every little helps the environment, I have changed from standard mineral based greases to Shell Naturelle, which is what we have to use in the underwater bearings for the hydro-electric station.
It is very much designed for underwater, high pressure use, and is approved by Rolls Royce, no less, for rudder carriers.
shell-naturelle-range.pdf
The grease details are on the last page.
If you have difficulty getting hold of some, I might be able to scrape out an 18kg tub and send you a litre.... :)
Thanks, that does look interesting - especially as the boat is on a lake. However, it looks like I'd have to buy either 18kg of it, or a dozen 400 gramme cartridges seems to be the smallest quantity I can find! If you do have any scrapings spare, I'd be willing to give you something for a litre!
