davidpbo
When we first got our boat I serviced/replaced the bearings as necessary and used Duckhams Keenol grease, now sadly no longer available. I am about to inspect/service prior to end of season pull out.
If I replace the grease should I use waterproof? Does it offer additional protection to the bearings. They are tapered roller bearings ang get dunked (Cold because there is always rigging/derigging before hand).
Am I likely to find waterproof sealed bearings as a replacement to tapered bearings?.
The cables are more than ten years old. How would you check for corrosion? They were liberally filled with oil when I got them.
Wish I could find the Indespension trailer servicing book I used to have.
Have found the relevant section on line here
Also similar for Knott
