gusboy
New Member
Would you know if the compression I’m getting is okay. It is 295psi on three cylinders and around 245 psi on one cylinder, this test was done on a cold engine.The basic problem of converting a petrol engine to diesel with the need for double the compression ratio without there being a starter motor with sufficient oomph to turn it over fast enough. As I suggested, this was a low budget project with very small numbers of engines built and the 24V for starting was the "fix". Starters were a problem on all the 85 bore engines - short stroke and high compression ratios compared with other engines of the time and dear old Lucas could not keep up with developments.
