Boo2
Hi,
My engineer has finally (after 16 months !) got the new engine and fuel tank placed inside Sunrunner for a look-see before nailing it all down, see this pic :
As you can see, there's not much room behind the engine and in front of the tank so I was wondering about trying to obtain a split waterlock that can straddle the prop shaft. Leaving aside the issue of access to the stern gland for the moment, does anyone know where such a split waterlock can be obtained ? An alternative would be to have one specially made up in stainless, anyone know where this can be done at a reasonable price ?
My default position (the engineer's actually) is to put the waterlock behind the tank, but this will result in it being quite a bit higher than if it could be mounted directly behind the engine so I am prepared to take some trouble to do that if at all possible.
Finally, does anyone here have any experience of the type of waterlock that vents the water directly below the hull into the water, leaving the exhaust gasses to exit in the normal way via the transom ? This might be one way to alleviate the problem of the increased height if I have to situate it behind the tank ? Or am I barkign up the wrong tree here ?
Many thanks,
Boo2
Many thanks,
Boo2
