wiggy
You may remember I posted a couple of weeks ago about accumulator pressure. I'm glad to say I recon I've got the pressure sorted but I'm still suffering with a massive temperature fluctuation as the pump and accumulator take it in turns to push the water around my system. I have a brand new thermostatic mixer valve installed just by the hot water tank and a 2litre accumulator fitted just by the Jabsco pump.
As the pressure at the tap changes due to pump or accumulator pushing water the temperature fluctuates massively from all cold o all hot. Changing the setting on the mixer valve does not solve the problem. Would fitting the mixer valve at the heads tap/ shower possible give a smoother temperature? I've got to sort this as the shower is now un usable.
