water tank gauge
An old trick ... is to fit a Y piece into the outlet pipe and a second clear plastic pipe fixed vertical with open top end .... or at least a plug with a small air-hole. In fact to keep things clean - you could always connect top of pipe into the filling hose to close the circuit.
Behind the pipe is fixed a plate with dark lines at 45 degrees ..... sort of like a barbers pole idea.
The level of water in the pipe will be same as level in tank and the lines behind will have a change of angle where the top of the water is .
another indicator is a small pastic ball in the pipe similar to a kettle indicator.
Simplest idea - no electrics involved and works for diesel, water ..... etc.
Funny really - but I have to dip my diesel tank / water tank with bamboo sticks, not same one of course !! - and always intended to fit sight tubes .... just one of those jobs you never get around to .....
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
Talbot
23 Aug 2003
Brighton, UK
even older trick is to buy a semi-transparent tank from tek tanks, then all you have to do is look at it! - works for me!
Teetime
10 May 2002
Get in touch with Mid-Service Centre Ltd, Their E-Mail is te@msc.te... Telephone 0121-354-5552. I have fitted one of their water tank gauges .The sender fits in the outlet pipe of your water tank. Easy to fit and works fine.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by Teetime on 21/08/2004 20:30 (server time).</FONT></P>
Talbot
23 Aug 2003
Brighton, UK
I dont much like the tube attached to the side of the tank, it provides a weak point, that could be broken, and then lead to los of contents inside boat. For the same reason, my fuel is drawn from a tube coming in from the top of the tank, rather than a take off at the lowest point.
Maybe I am just paranoid, - or is it that I am sane and . . . . /forums/images/icons/crazy.gif
A
Anonymous
[/ QUOTE ]Do you, or does anyone else have any further experience of this product since August? Or any alternatives that don't require radical metalwork mods to the water tanks or cost £200+?
