evangeline44
Active Member
I'm replacing my 3 watertanks with plastimo type flexible bladders.
My query is probably basic physics but I just can't get my old head around the following quandry:-
Each of the tanks is fitted with one inlet and one outlet.
No breathers are provided.
When installed the Number 1 tank will be filled directly from the deck filler (this tank is higher up in the boat than the other 2).
Can I then pipe from its (the No.1 tank)outlet to the other pair of lower tanks (call them No.2 and No.3) Inlets via a Y connector?
I wish to draw water from one of these tanks outlets into the pumped system for the galley/heads and calorifier.
This leaves me with one unused outlet fitting on either tank 2or3 should this become a breather pipe or do I just blank it off?
Very confused
Very confused
