Tim Good
I have a stainless tank and fill it on deck like most others. I have a gauge from Tank Tender which pumps air down a tube and it works.
However, I fixed my watermaker and when I was happy the water quality was good I switch the divert tap to the tank. After about 5m mins it was making some pretty impressive expansion noises so I went outside and undid the main deck screw cap and the air pressure the released was immense! Clearly my tank is not breathing for pressure build up that much when the water maker is on.
Should it breath and where would the breather pipe tend to go? Access is tricky and I can't see any sort of obvious breather pipe in the top of the tank.
