Tugw
Went down the boat today to install a new fresh water pump.Removed the old burnt out pump and started to sort out the wiring so it would reach the new one.I found a seperate pair of wires taped back out of the way.i traced this pair back to a pull-switch in the shower that is marked as Bilge/Shower i tested the circuit and sure enough it is energised when the switch is 'made'. Now.my question is this.There is a bilge pump and a fresh water pump.At the moment there is no calorifier fitted(another job for later) could there have been a second bilge pump for the shower or are these wires supposed to connect to the 'normal'bilge pump as well as the 'normal'supply(i cant see how this would work,but im thick)i can confirm that they are a separate pair of both positive and negative so i dont think its a two-switch circuit with a 'hot'wire .Anybody got any ideas?
