Water pump wiring... what is signal wire used for?
EugeneR
21 Aug 2009
Hamble
I have replaced my water pressure pump. The boat has 3 wires coming to the pump, connecting to 3 wires on the pump. Positive, negative and a signal wire which looks to returns positive when the motor is operating, otherwise negative. My new pump has 2 wires only, and works, but there is no feedback to the boat when the pump is running.
I could tap the connection between the motor and pressure switch to get the same feedback, but am wondering why the boat needs the feedback wire? I am not aware of any indicator that lights up when the pump is running, the noise is enough. I assume Fairline would not have put it there without reason, but what could that be? I am not able to trace the wire.
The old pump on my Fairline had this connected back to an indicator on the FW pump switch, so it would flicker on when the pump ran. I could have made an extra connection to the pump after the pressure switch, but as I can hear the pump running I thought 'space and waste of ...'
