chrism1
hi been noticing water in my bilge and when the water pump is on it by-passe with a small discharge into the bilge. upon investigation i niticed a relief valve attached to the hot water cylinder in the engine bay. with this it has the flow and return from the engine and also a adjustable relief valve? if turned it disharges continually and if adjustated the other way it discharges when the water pump is engaged. anyone got any ideas is this correct or is it fulty. i believe it shoud'nt always discharge when the pump is working!!!! any info would be a great help
