Water pump on Thornycroft 80D
andybussell
21 Jul 2004
I have a leak from the back of my raw water pump and have removed connecting pipes & impeller.
Can anyone explain how I now remove the pump from the shaft please?
Thanks in expectation.
omega2
17 Oct 2002
Essex Bradwell UK
I think the base engine a ford, is the pump fitted at the rear of the timing case under the distributer pump? if so it is held by three nuts, and withdraws from the rear of the timing case. the shaft can then be removed by removing the gear wheel.
