JonoSlatter
Active Member
Hi all,
I’m getting a rapid on/off rattling from the pressure relief valve (PRV) on the calorifier on my 336 – see video below.
Youtube
The water pump is a Shurflo 2901-0213, probably around 10 years old.
It started with the PRV briefly opening and shutting every minute or so, with the pump kicking in for a second each time. Now, as soon as I turn the water system on, the PRV rattles continuously and discharges a significant amount of water.
What I’ve tried so far:
Thanks,
Jonathan
Youtube
- Adjusted the pump pressure (full range) – no change
- Replaced the PRV (now on my third 3-bar valve) – no change
- Could the pump be the issue (pressure spikes or failing pressure switch)?
- Or is there something else I should be checking?
Thanks,
Jonathan
