Water not getting through. Ideas?
funkydad
New Member
15 Feb 2005
I have a full starboard water tank but no water getting through to the pump.
No problems with the forward tank.
Any ideas?
TIA
There are surely only 3 possibilities:
1/ Pipe from tank blocked
2/ There is a valve that is closed
3/ Tank is empty
Presuming there is water in it & there are no valves in system, could you not take off the inlet to the pump from that tank & try blowing through it?
Any ideas?
TIA
Is this a new problem? if so, what did you last do to the tank?
If we empty our galley tank it can take a while after filling to get water running again, this was worse after I fitted a new whale gusher pump; I found placing it at a slight angle seems to help. But I do not have pressurised water and don't really know the associated problems that comes with pressurised systems.
Is your pump gravity fed?
Another problem I had was with the shower pump, this just stopped working after a week... the impeller was just spinning on the shaft, hard to spot as when there was no water pressure it appeared to be working fine, i.e. visually.
Just a couple of thoughts to maybe consider.
