ironmaiden
on Tuesday I orderd a shaft, water lubricated bearing and coupling from T Norris, they all came on friday, now thats a good company with good service, no connection just well impressed.....any ways.....
the bearing is composit cos it's going into a steel tube, all those I've used in the past have had a hard resin shell with internal rubber for the bearing this one hasn't it's just rubber, and all quite flexible.
So, have any of you lot used this type before and do they stay in place in the tube ok using the normall couple of grub screws on each side of the stern tube. I have visions of it just spinning around with the shaft untill it rips its self apart.
regards rachel
regards rachel
