Daydream believer
Engine is a Volvo Penta 2020 MD Sail drive
Never had a problem with water cooling on sea water side in 13 years from new until August when I had a lift out for mid season pressure wash.
When I started engine no water came out & i had to prime the system at the filter. I guessed perhaps some dirt had been pushed into the slots in the saildrive.
Everything worked OK & I motored out of Burnham yacht harbour & sailed to the Swin.
Due to shallow water I decided to start the engine in case I ran aground & no water came out. I checked impeller & had to change as running dry for a few minutes lost a vane.
Still no water in spite of pouring water in to the filter with a kettle.
Finally got water in by laying boat over ( 25Kts wind) on inlet side & then starting engine
Motored into Bradwell OK
2 weeks later started engine & water came out immediately
Sailed to Ostend & no water until I did the same trick of laying boat over
berthed for 24 days & water came out strongly & immediately
Sailed to Flushing & no water again
The sea water pump recently had new shaft & seals fitted & there is no leak. The pipes & all water connections have been checked. I do not open & close the sea cock between the use mid season
Any ideas as to why all this is happening after I sail the boat please
